Hi everyone, so I currently use the Logitech G502 Proteus and I've been wanting to go to a Wireless Mouse. I just saw the G602 went on sale for $25, and I was wondering if anyone has tried them both to see if there's a big difference or which other one you would recommend? I mainly play FPS about 95% of the time. Thank you all for your time.
https://linustechtips.com/topic/1087318-wireless-mouse/
In theory there is far more latency with the G602, but it will come down to you personally. I personally didn't perceive much of a difference in terms of latency between my G502 and Performance Mouse MX, but others will swear it's game changing. If you really want to go wireless, then just pick it up and you can always return it at no cost to yourself if you decide you don't like it.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/1087318-wireless-mouse/#findComment-12755738
I'd say if you want the same performance as a wired mouse, take a look at Logitech's newer wireless mice, like the G502/703 Lightspeed/G305/G Pro Wireless
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/1087318-wireless-mouse/#findComment-12757254
