So for the past week IV had nothing but random issues. Random unlinked postcodes, Post coat hangs, BSOD ERRORS all seemingly different, hibernation/ sleep mode cycle crashes, graphical erroes, exceedingly slow R/W rates the works and as soon as one problem would start it would disappear just as mysteriously thankfully I have two drives my boot and my libraries. Ended up doing a complete reinstall so as it turns out so far this has fixed all my issues. Hopfully this pattern holds as I reinstall the majority of my software so far everything is holding together.
Anyone else experiance a similar issue?
  • CPU
    Ryzen 3700x
  • Motherboard
    Asus rog hero vii
  • RAM
    Corsair pro rgb 16gb 3400 oc stock timings
  • GPU
    Radeon Vii
  • Case
    Thermaltake G21 TG
  • Storage
    My digital ssd 250gb pro m.2 (boot) 2tb berracuda 7200rpm +Toshiba x300 4gb 7200rpm
  • PSU
    Evga g3 750
https://linustechtips.com/topic/1086990-massive-problems-now-gone-o0o/
