Hey Gamers,
I am planning on building with the new ryzen 3 gen. There is nothing wrong with my current system and in fact its perfectly capable, so I wanted to slowly build it.
I am planning on buying CPU and Motherboard first as its all unique. I will then probably follow it up with a new cooler as I lost the AM4 bracket for my current one. I will then probably go for the case as I already have 3000mhz ram that I will upgrade after the GPU. I have perfectly fine storage and the intel ssd is just a touch on top.
idk tbh
https://linustechtips.com/topic/1086152-ryzen-3-build/
7 hours ago, Greenish said:
Go with this one instead. .
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($523.00 @ Shopping Express)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($119.00 @ IJK)
Motherboard: Asus PRIME X570-P ATX AM4 Motherboard  ($289.00 @ PLE Computers)
Memory: G.Skill Sniper X 32 GB (2 x 16 GB) DDR4-3600 Memory  ($241.91 @ Newegg Australia)
Storage: Crucial MX500 1 TB 2.5" Solid State Drive  ($160.00 @ IJK)
Video Card: Gigabyte GeForce RTX 2070 SUPER 8 GB GAMING OC Video Card  ($904.10 @ Newegg Australia)
Power Supply: Cooler Master MWE Gold 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($104.00 @ Shopping Express)
Total: $2341.01
Generated by PCPartPicker 2019-07-25 22:16 AEST+1000
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1086152-ryzen-3-build/#findComment-12748406
Total: $2341.01
I know that this seems petty and sorry if I am putting your build down in any way, but I wanted to make it look as good as possible. Dont get me wrong, this build will look fine but its just that I wanted to go with the same aesthetic for most PC-O11 builds.
About the Cooler, I wanted to use a NZXT one bc they look epic af and will fit nicely in the PC-O11.
About the RAM, I have 16GB of that same ram, overclocked to 3400ish, I will put that in and purchase that RAM later most likley keeping the 2x8GB sticks I have making it a total of 48GB.
About the GPU, I am not sure what the differences are between a 2070 super and a 2080, I basically only play overwatch and I need atleast 240fps on medium low settings while streaming, if it is noticeable, I would rather pay the extra $70ish for a 2080.
About the PSU, The current PSU I have is fine and I would rather not get another one.
I have lowered the price quite substantially in the build below, I will most likley buy more faster ram, when I have bought and built the rest, I would prefer to finish building the build with the new parts before buying faster RAM when it won't make (as far as I know) a large difference. I will be sure to buy faster RAM in the future. I was told that ASrock; while having a shitty name for mobo's , made seriously good AM4 boards (correct me if I'm wrong). I have had nothing but good experiences with Corsair and especially their AIO's.
https://au.pcpartpicker.com/user/GreeenishSpam/saved/PH3dmG
idk tbh
https://linustechtips.com/topic/1086152-ryzen-3-build/#findComment-12764116
Nzxt cam software has issues with the zen 2 platform. They don't work well together.
Asus prime x570 p uses way better vrms as compared to gigabyte x570 gaming x.
The difference between a 2080 and 2070 super is not much. 2070 super is a stripped down 2080. But if you still wanna go with a 2080, I'll recommend you to go with a 2080 super.
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1086152-ryzen-3-build/#findComment-12764557
Something like this would look and perform even better...
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($518.00 @ Shopping Express)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler  ($119.00 @ PCCaseGear)
Motherboard: Asus PRIME X570-P ATX AM4 Motherboard  ($288.00 @ Shopping Express)
Video Card: EVGA GeForce RTX 2080 SUPER 8 GB BLACK GAMING Video Card  ($1199.00 @ PLE Computers)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($149.00 @ PCCaseGear)
Total: $2778.91
Generated by PCPartPicker 2019-07-31 13:21 AEST+1000
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1086152-ryzen-3-build/#findComment-12764566
14 minutes ago, dgsddfgdfhgs said:
Ryzen 3 Build =/= Zen 3
think of low end budget build lol
He actually meant zen 2
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1086152-ryzen-3-build/#findComment-12764617
Taking in to account what you have said, I swapped over to the Corsair H150i Pro as its cheaper, and will match with my RAM, also there are no issues with Zen 2 as far as I am aware.
I am not a huge fan of the chipset fan on the X570 and it is even more noticeable on the Asus board. From a post I put out a week or so ago, I got pointed to ASRock but correct me if I am wrong making this decision.
From what you said I upgraded to the 2080 Super.
I am not a huge fan of air cooled systems (get it) and I have always wanted to build in the PC-O11 which doesnt really fit well with an air cooler.
idk tbh
https://linustechtips.com/topic/1086152-ryzen-3-build/#findComment-12765443
idk tbh
https://linustechtips.com/topic/1086152-ryzen-3-build/#findComment-12765444
How about these changes...
CPU Cooler: Cooler Master MasterLiquid ML360R RGB 66.7 CFM Liquid CPU Cooler  ($165.00 @ Austin Computers)
Motherboard: ASRock X570 Steel Legend ATX AM4 Motherboard  ($328.90 @ Newegg Australia)
Case: Fractal Design Define C TG ATX Mid Tower Case  ($149.00 @ IJK)
Total: $642.90
Generated by PCPartPicker 2019-07-31 23:34 AEST+1000
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1086152-ryzen-3-build/#findComment-12765513
9 hours ago, trevb0t said:
Idk, it looks really clean and nice, and I am wanting to fully custom watercool it later on. I am ideally wanting to stick to corsair to use the old fans (6x LL120'), Corsair Commander Pro, and the light strips together.
idk tbh
https://linustechtips.com/topic/1086152-ryzen-3-build/#findComment-12767231
Total: $642.90
Like I said to someone else about using Cooler master, I wanted to stick along with corsair as I already have 6x LL120 fans which look sick af in the PC-O11. For the Mobo, I wanted to know what the key difference is (aside from the rgb and shroud) between the steel legend, and the phantom gaming.
idk tbh
https://linustechtips.com/topic/1086152-ryzen-3-build/#findComment-12767235
