What is the purpose of the build? What CPUs are you comparing? What is the budget?
CPU: i7-4770k CPU Cooler: NH-D14 RAM: Crucial Ballistix Sport 8gb GPU: EVGA Superclocked 780 ti MOBO: ASUS Maximus VI Gene PSU: Corsair RM 850 Case: Bitfenix Prodigy M
Why would the question "Stupid Question. AMD or Intel?be stupid...although you just elaborate more on between which micro processor and the socket architecture/chipset?
@PhantomTheOrphan can you post you budget? Will you be running a dedicated graphics card along side the processor?
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
Post in the new builds and planning section about your build and we will help you and read this first http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
That may be true that he should've instated between choosing a build/processor as a fundamental concrete base but he sounds pretty new as he suggested in his post.
@PhantomTheOrphan You should read the posted link that is hyperlinked in the blue font given by @lilc GJ :D
Depending on the motherboard that you currently have you will only be able to go with AMD or Intel depending on that motherboard. Could you list the motherboard model#?
Also, you mentioned that you are doing editing work what programs are you using and what is your current budget to get things afloat?
Also, what parts remain?
Monitor/ Resolution? i.e., 1920x1080, 1920x1200, 1920x1440.
Memory/Ram?
Hard Drive?
Graphics Card?
CPU?
CASE?
OS?
