Hi guys.
I have a phanteks shift case. I want to go Dual AIO. I currently have an RTX 2080 Asus Turbo (blower style) as i thought this was best for this kind of case without going watercooling.
It's not bad.. it reaches around 72 degrees max but can get loud. Seen the RTX 2080 Super EVGA hybrid card - would this fit in this kind of case? Then again, I wanted more performance so kind of want a 2080ti... but then again the price difference between the two is ridiculous (£799 vs £1399).
https://linustechtips.com/topic/1085585-2080-super-in-phanteks-shift-case/
EVGA hybrid cards are amazing. Built my friends pc for him and he got a used 1070 hybrid off of letgo and its an amazing overclocker and runs quiet and cool. Assuming the hybrid you're looking at utilizes a 120mm AIO, as long as the case you have has support for that it will work just fine
Desktop: NZXT H700i / i7-8700K @ 5.1GHz / Corsair H100i RGB AIO / Asus ROG Strix RTX 2080 Ti OC / 32gb Corsair Vengeance @ 2666MHz (8+8 LPX, 8+8 RGB Pro)
Laptop: Asus ROG Zephyrus GX501 15.6” / i7-7700HQ / GTX 1080 Max-Q / 16gb DDR4 (want to liquid metal it soon!)
