Did you contact origin?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1085499-origin-problem-helppp/#findComment-12742811
Are you using a VPN/Proxy/Tor?
https://linustechtips.com/topic/1085499-origin-problem-helppp/#findComment-12742814
i Also had that problem and tried to download Origin from other site.
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
https://linustechtips.com/topic/1085499-origin-problem-helppp/#findComment-12742815
Just now, Randomguy123 said:
well the only way to connect as i see it is through the phone and i just broke it a day ago
So you have no way of sending an email to customer support?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1085499-origin-problem-helppp/#findComment-12742820
What do you mean other site ?
The installer.like in Filehippo.com
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
https://linustechtips.com/topic/1085499-origin-problem-helppp/#findComment-12742829
did that work ?
yeah but i forgot where i installed the client tho
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
https://linustechtips.com/topic/1085499-origin-problem-helppp/#findComment-12742839
11 hours ago, yaboistar said:
jesus fucking christ take your capslock off
have you considered that origin's servers might just be having an outage.
Seems weird when other people can access Origin while i cant !
and for almost 1 day + the servers are out?
https://linustechtips.com/topic/1085499-origin-problem-helppp/#findComment-12744606
