Your stereo separation is not determined by your monitors, but rather by your PC. Which means that the output of both monitors will be the same anyways.
Unless you are talking about 2 monitors connected to 2 different PCs, then yes there is a way. Get an 3 RCA to AUX cables, 2 from both monitors going into the left and right channel of the cable going to your headphones. Then of course you will have to set your audio outputs to mono so you don't miss any audio information from either side.
In any case that is a strange way of doing things, and I don't know what you are trying to achieve, maybe you can give us more information?
