Hey guys
I've recently bee looking into upgrading my graphics card because my GTX 660 just isn't cutting the latest titles on ultra with a stable frame rate. The card I think looks solid is a GTX 780 because I play at 1080p but I like an average frame rate of 120. It would be very helpful and much appreciated if someone could give advice and experiences they have had with this card and the latest titles.
What FPS do you get with the settings maxed out on 1080p with?:
-Battlefield 4
-Assassins Creed Black Flag
-Call of duty Ghosts
-Far cry 3
-Crysis 3
Also wanted to know if I'll be getting any bottlenecks with an i7 3820?
https://linustechtips.com/topic/108507-gtx-780-any-problems/
only AC4 at max and Crysis 3 at max will give you some problems.
(AC4 is an unoptimized mess, and Crysis is demanding)
AC4 is actually fixed now :), i get an easy 100 + FPS on TXAA x4 and everything maxed :P ,
But the answer to your question not really just with games that are mainly AMD based you will see a few less frames than AMD cards would cause that game is of course optimised for AMD.
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/108507-gtx-780-any-problems/#findComment-1450452
fixed my ass, I still get 25-30 fps in some areas with my 770, not even maxed.
but good for you. :)
"Probably Because I'm A Dangerous Sociopath With A Long History Of Violence"
https://linustechtips.com/topic/108507-gtx-780-any-problems/#findComment-1450455
You lucky so and so. I played AC4 yesterday and I wasn't getting above 45 FPS ):
https://linustechtips.com/topic/108507-gtx-780-any-problems/#findComment-1450457
crysis 3 will be be fine and i agree with AC IV , I have sli titans at 1440p and it dips to 30 quite often
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/108507-gtx-780-any-problems/#findComment-1450460
seriously ? , Ouch unlucky :L maybe they still have the odd thing or two to tweak but that Ubisoft for you aha
Current Build :
Laptop:
 CPU:
https://linustechtips.com/topic/108507-gtx-780-any-problems/#findComment-1450476
this is strange as i said to Jago how, people with 770 and titans are having problems yet my 780 is not this is very strange i must have won the silcon lottery aha YEA I WON SOMETHING xD
Current Build :
Laptop:
 CPU:
https://linustechtips.com/topic/108507-gtx-780-any-problems/#findComment-1450478
And still wondering if any bottlenecks would occur with the 3820??
No, you should be fine.
My Rig:
Case: NZXT H210 CPU: AMD Ryzen 7 3700x  Motherboard:  MSI B450 AM4 Motherboard  Memory: GeIL EVO POTENZA 16GB Video Card: MSI RX480 Power Supply: Corsair TX 750w Storage: Samsung 840 120GB And a 500GB WD BLUE Monitor: Acer S231HLbid 23" and an old Dell Mouse: RAZER DeathAdder 3.5G Keyboard: Ducky DK9008G2 PRO MX Cherry Blue
https://linustechtips.com/topic/108507-gtx-780-any-problems/#findComment-1450558
my i7 920 does not bottleneck my 2 780s when I tested it so your i7 wont be bottlenecking anything for a good long while.
you wont be getting 120FPS on games like crysis 3 on ultra with even 2 780tis. really I would look at getting a second 660 if you can find one for under 200. because all the games you listed have really good sli scaling. or I would just lower settings down to high (still looks just as good IMO) and wait for GTX 880 in a few months.
Thanks :) I'll wait for the 880 in a few months and just buy another 660 now :)
How much better do you think the 880 will be in compare to 780-780ti?
https://linustechtips.com/topic/108507-gtx-780-any-problems/#findComment-1452734
