Dan A4 build for gaming advice?
9 minutes ago, Sorenson said:For your build I would go with he Asetek 645LT and a 2060 super. The 2060 super is essentially a 2070 that costs $40 less. The Noctua L9i should be fine, but it might limit your overclock. The Asetek 645LT should give you better OC room because of the limited air flow in the Dan A4. You could also go with an i7 9700k. I would not recommend any of the Ryzen 3000 processors. I just built a new system in the evolve shift and had to swap out the 3700x for the 9700k because the thermals were uncontrollable on the 3700x.
I will consider the 2060 super then! What style do you think is better for this build, blower or dual fan. I hard 3 fan gpu might not fit in this case if using liquid cooling. If I decide on going for the i5-9600k and the 2060 super, would I need to do some tweaks? seen some people talking about delidding(im a noob) will that be neccesary? Thanks alot!
