10 minutes ago, birdwarrior said:
Requirements:
-Gaming
-At Least 144Hz 1080P 1MS
-i9 9900kf
-Decent Overclocking
-Watercooled 360mm
I already have the case, power supply, OS, mouse keyboard, and storage.
What I picked out, but would like second options on: https://pcpartpicker.com/list/hdrVsZ
Thanks in Advance
For very similar performance, you could pickup a Ryzen 3700x instead and save a couple hundred bucks. You could also get a 3900x for the same price and get better performance in multithreaded apps. Gaming performance is off by literally 2 or 3 fps on most games, well within the margin of error
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
https://linustechtips.com/topic/1084504-build-help/#findComment-12735495
1 hour ago, birdwarrior said:
Requirements:
-Gaming
-i9 9900kf
-Watercooled 360mm
Thanks in Advance
Don't get a 9900K especially if just gaming. An 8700K or 9700K would do fine for less money. In any case that board is rubbish for a 9900K especially as you mention overclocking. A Gigabyte Z390 Aorus board is what you should be looking at for that.
Or if you don't mind losing a few fps depending on the game then a 3700X would be a cheaper option, or even a 6 core 3600/X.
https://linustechtips.com/topic/1084504-build-help/#findComment-12735606
@lee32uk I honestly prob don't, there sometimes I max out my 16GB so I figured I would go to 32. I do already have 2x8GB 2400MHz DDR so I could lessen it to just getting a extra 16GB Kit. but honestly if the difference is only 100 from Intel 9900k and 3700X I don't mind spending that if intel is overall gonna give me better frames, I only wanna game and stream.
https://linustechtips.com/topic/1084504-build-help/#findComment-12735702
At 1080p 144Hz Intel does have the edge, but as I mentioned you want to get a better board.
The Gigabyte Z390 Aorus Pro wifi is what I would suggest.
https://pcpartpicker.com/product/N6gzK8/gigabyte-z390-aorus-pro-wifi-atx-lga1151-motherboard-z390-aorus-pro-wifi
https://linustechtips.com/topic/1084504-build-help/#findComment-12735733
PCPartPicker Part List
Type Item Price
CPU Intel - Core i9-9900KF 3.6 GHz 8-Core Processor $419.99 @ Walmart
CPU Cooler Corsair - H150i PRO 47.3 CFM Liquid CPU Cooler $189.89 @ OutletPC
Motherboard Gigabyte - Z390 AORUS PRO WIFI ATX LGA1151 Motherboard $179.99 @ Amazon
Memory Crucial - Ballistix Sport LT 32 GB (4 x 8 GB) DDR4-2400 Memory $76.00
Video Card MSI - GeForce RTX 2080 8 GB VENTUS Video Card $609.99 @ Newegg
Monitor AOC - C27G1 27.0" 1920x1080 144 Hz Monitor $229.99 @ Amazon
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $1745.85
  Mail-in rebates -$40.00
  Total $1705.85
  Generated by PCPartPicker 2019-07-20 18:11 EDT-0400
https://linustechtips.com/topic/1084504-build-help/#findComment-12735752
