Hi there.
I am quite new to this and I new a little help with choosing a Micro ATX case.
I Have a few ideas but i am not to sure.
The two cases I am currently looking at are:
Fractal Design Define Mini
Corsair 350D
I wish to make the PC as quiet as possible. Any help is very much appreciated
Thanks
Full specs:
Mobo: Asus A55BM-A usb3
CPU/APU: Amd A8-5500
RAM: Kingston Hyper X 8Gb
GPU: Msi GTX 760 Gaming edition OC
PSU: InWin GreenMe 650 watt
1 TB harddrive
Coolermaster Cpu cooler
Intel i5-4670K, Asus Maximus VII (z97), 16gb Kingston, Asus Gtx 780, Fractal Design Define Mini, 250Gb Samsung Evo, Corsair CS650M
        Yey dis meh Pc
https://linustechtips.com/topic/108420-micro-atx-pc-case-help/
Hi there.
Corsair 350D
Thanks
Full specs:
1 TB harddrive
Either choice will be extremely quiet :) just make sure you have enough clearance for whatever cpu cooler your using and youll be good to go. typically the fractral cases are a bit quiet btw but they lack the airflow of something like the 350d
https://linustechtips.com/topic/108420-micro-atx-pc-case-help/#findComment-1449326
It's not a great build. Strangely unbalanced. What is your budget and location if this isn't built already?
As for the case, the Define Mini is the quietest.
https://linustechtips.com/topic/108420-micro-atx-pc-case-help/#findComment-1449332
The Define Mini is sound dampened and doesn't have a window, the 350D isn't sound dampened but does have a window. So the fractal should be a bit quieter.
It really depends on the kind of CPU cooler and fans you choose. Noctua and bequiet fans/cpu coolers can effectiveley bring down the noise of any system.
btw. why an APU AND a dedicated GPU? wouldn't a FX CPU be a better choice? Like the FX 6300
Edit: let ^TheSLSAMG help you. :D
who cares...
https://linustechtips.com/topic/108420-micro-atx-pc-case-help/#findComment-1449342
Yeah it isn't the best I am planning on upgrading the Cpu/Apu .But at the moment its good. I might eventually get intel but that wont be for a while.
The problem really is my Budget and being in Australia doesn't help with the prices. What might be 100 dollars in the states can be 150 dollars in Australia. Really Sucks!
        Yey dis meh Pc
https://linustechtips.com/topic/108420-micro-atx-pc-case-help/#findComment-1449375
First of all, what's your budget? And it makes it a lot simpler to research and get part prices from different shops if you use pcpartpicker.com
The Silverstone SG10 (same thing as the SG09, but with an updated not as horrid looking front panel) is the most space efficient microatx case (meaning it's the smallest micro atx case that can stuff great components)
The Corsair 350d looks really sleek, but is quite big for a micro atx case
The Silverstone TJ08 is pretty compact and also quite space efficient for a micro atx case. Definitely a good contender you should look at.
The define mini is the only good "silence optimized" mATX case out there
The FT03 has a very nice design and a pretty original internal layout. Also takes up very little space on a desk because it's mostly vertical.
The Arc MIdi R2 is a simple case, but it works great.
"Common sense is not so common." -Voltaire
https://linustechtips.com/topic/108420-micro-atx-pc-case-help/#findComment-1449386
The Build is a little bit of a Frankenstein, It originally started of as a Branded Hp Pc and I added and took away from it. Only recently I have  taken an interest in the AMD APUs. In a way it is a back up for if my gpu has any problems. Budget is also another thing being only 15 makes it quite hard to find the money for high end pieces so I do what I can. Overall my Current financial state is what is holding me down.
        Yey dis meh Pc
https://linustechtips.com/topic/108420-micro-atx-pc-case-help/#findComment-1449424
Thanks for the suggestions
        Yey dis meh Pc
https://linustechtips.com/topic/108420-micro-atx-pc-case-help/#findComment-1449432
