Power problems?
Go to solution Solved by Fasauceome,
The additional 4 pins are not required
I'm moving from an i5 7600k to a ryzen 7 3700x
I got a x570 mobo and I'm seeing the cpu now has 8+4 whereas my old one only needed an 8. My psu doesnt have additional pins for cpu and the PCI-e pins wont fit
Do I need to buy a new psu or am I missing something simple?
Psu is a 750 cooler master and the only modular slots are for hdd/sata expansions
https://linustechtips.com/topic/1083867-power-problems/
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1083867-power-problems/#findComment-12730846
you should be fine on a single 8-pin
those can delivery around 380W* on their own, your CPU is unlikely to exceed that
*not sure, but should be around that
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1083867-power-problems/#findComment-12730865
