Silent Air coolers
Umbranoctuna
i just bought a Ryzen 7 3800x and with the stock cooler its getting kinda toasty in some benchmacs (91°C peak)
i tought about getting a Dark Rock 4 or a Dark rock Slim. (Dark rock 4 might give me problems with my RGB Ram
i heard noctua is also realy good, however their look doesnt fit my build.
or should i just go for an IAO, if yes, wich are the good ones?
AIOs will be louder than any of the two you listed. DRP4 is a good bet.
I use a D15 with their black chroma covers- it looks better than your think
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
What ram is it specifically? One thing to keep in mind is that you will probably not be able to see the RGB anymore, if that matters to you.
~Air Cooling Advocate~
What case and ram are you using?
Where are you shopping / located? Budget?
