Which header for pump
Go to solution Solved by Metallus97,
1 minute ago, AYDANN6ix9ine said:
This will even work with one Fan header and a normal power connector form the PSU... BUUUUT you have to give me a specific unit you want to buy in order for me to check it for you
In general: Buy! ALsomost everything will be compatible
So I have been thinking of upgrading to an AIO after making some money but I need to check compatibility with my other components. So assuming the AIO I get has two fans with a splitter to use one header and one cable for the pump, which headers should I use? My motherboard has two system fan headers and one cpu fan header. I plan to use the two fans with one of the system fan headers and the pump with the cpu fan header. Is this setup going to work properly or do I have to setup my fans and pump a different way. Thanks for any insight.
https://linustechtips.com/topic/1083214-which-header-for-pump/
2 minutes ago, Metallus97 said:
Probably yes, but I need to know wich AIO you're going to use on wich mobo!
I'll just give this AIO as an example.
https://www.amazon.com/Enermax-LIQMAX-Performance-Liquid-ELC-LMR120S-BS/dp/B00QWZIN9W/ref=sr_1_1?crid=2N42GR740R3O&keywords=enermax+liqmax+ii+120s&qid=1563317859&s=gateway&sprefix=enermax+liqmax%2Caps%2C207&sr=8-1
https://linustechtips.com/topic/1083214-which-header-for-pump/#findComment-12725799
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/1083214-which-header-for-pump/#findComment-12725804
