2080 ti not detected
Go to solution Solved by Xquasare,
22 minutes ago, xAcid9 said:
Try that, or update to 1809 at least if you want to use RTX.
I just updated and it seems working without a problem so if anyone gets this problem like me just UPDATE your windows.
Did u have any drivers for video installed previously?  If so use DDU to uninstall these and restart PC.
Are u attempting to install latest driver from NVidia?
Have you tried downloading the driver direct from MSI website for your card?
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 990 Evo Plus NVME PCI-E 2TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Printers Include -Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer BE9300 Triband Cable Router Wifi6 with a Virgin Media Hub 5.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S25+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/19284824949
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12725219
I can not install any drivers so can not use ddu.
Yes i am attempting to install latest driver from Nvidia but its no use.
I havent tried it yet but now i will btw my psu is Corsair RM750X.
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12725228
@Xquasare you need to you use geforce experience.Download
Just click on link download and install it.
My PC --- CPU: Ryzen 7 3700x @ 4.3 || MoBo: Asus strix x470-F || RAM:32GB@3400mhz  4x8GB Corsair vegeance pro RGB || Cooler: Corsair H150i Pro AIO || GPU: Sapphire Rx5700 XT nitro+ || PSU: Corsair rm750i || Case: Thermaltake TG 31 RGB || SSD: 1x hp ex900 nvme 500gb 3x crusial mm500 1tb || Corsair M65 elite & Corsair platinum K95 || 2x Acer ed323 qura 1440p@144hz + Samsung c27fg70 1080@144hz.tb
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12725231
I just tried installing but it says the same thing.
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12725238
6 minutes ago, Xquasare said:
I already have tried my friend it doens't work :( any suggestions?
Interesting.Standalone driver in windows 10 usually doesn't work.Graphic driver not compatible with this version of windows is a common error.
It seems windows inst detecting card properly.As it shows 0mb of dedicated memory.Try to remove it in device manager,then switch pc off and re-seat the card.
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12725244
@Xquasare just woke up :D,sorry about typos lol.To clarify go to device manager then uninstall card,shut down your pc.Switch PSU off and the take try to re-seat the card.As shown in your screenshot card haven't been detected by windows.
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12725263
I have uninstalled the card then restarted my pc and resolution changed idk why and i already have re-seated it but still no use.
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12725284
Check windows device manager if the card is detected this time.Resolution changed because windows didn't install drivers yet.
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12725297
Nope it didn't detect the card. If we just can find the problem it would be easy to solve it. Could my video card be DOA?
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12725319
@Xquasare Yeah go figure.Well,it is most likely cpu not making proper contact with sockets pins.Therefore pci express cant figure out the GPU.It does happens sometimes with new intel builds.You will need to re-seat CPU.
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12725336
Well i'll give a try.
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12725345
Well i tried relocated cpu many times still no effect.
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12725497
Well at his point i can only advise you to try card in different pc to find out,if the card is the problem.If not mobo has some bend pins probably.
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12725519
I wanted to try that but my other video card is stuck lmao. I will send for a RMA see if anything is wrong with gpu.
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12726569
What Window 10 version is that? Open RUN and type Winver if you don't know how to check.
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12726584
21 minutes ago, Xquasare said:
I am now updating it to 1803 see if anything changes.
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12726891
On 7/17/2019 at 12:03 PM, Xquasare said:
Now i have another problem it wont let me update driver. Anyone ever had this problem?
Wait you did clean install of geforce experience before didn't you?Back when you were trying to install drivers and card haven't been recognized.Btw sorry bro, i didnt realize that someone nowadays can have windows so out of date :D.You had to manually disable windows update.
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12731461
For a brand new card to work properly i would think you need to be on the most current version of windows (1903) I may be wrong,
Im not a software expert by any stretch but i had a friend just a couple of weeks ago had same issue. Once he installed 1903 it worked perfectly. If i were you i would try that.
https://linustechtips.com/topic/1083129-2080-ti-not-detected/#findComment-12731480
