Case recommendation #6576821
Hi,
I'm looking for a case for my next Ryzen 9 3900x build. There are so many cases and I don't really know what to choose from.
- Preferably not more than $70
- Must have support for a 2 fan radiator on top.
- Must be able to suck air from the front. I hate cases with a flat front panel.
- I don't care how it looks as long as it's functional.
CPU: AMD 3800X GPU: GTX 1080 Ti RAM: (16GB) 2x Corsair 8gb DDR4 3200Mhz Drives: SanDisk 240GB SSD, Samsung 500GB SSD, WD 1TB HDD
Motherboard: MSI X470 Gaming pro plus PSU: Gigabyte 650 watt Monitor(s): 27 inch AOC 1440p
https://linustechtips.com/topic/1082936-need-help-with-a-case/
Actually this will be case recommendation #6576824... Couple of late entries were filed recently ;)
Meshify C and TD500 have "non flat" looking front panels, but the Meshify C is usually $85-95, and the TD500 is a airflow choking hazard, so those are both out.
The MB500, K500 and MB511 RGB sorta fill this catagory. If you want something a boit more agressive you can get the Corsair SPEC-01 or -04 cant hold a rad at the top
Edited by TVwazhere
https://linustechtips.com/topic/1082936-need-help-with-a-case/#findComment-12724783
