Replacement to monitor speaker
jonfunko
hi there, I'm working on finding an alternative to my Monitors built in speaker, to use when not gaming so i can hear my room not using my razer manowar what would you recommend for a prime eligible in the us, sub 50$ set to connect to motherboard onboard audio, to replace it , ideally ild be looking for  a 2:1 but im not really sure what are good speakers or not,
Either find something used if you want something good but the sub $50 Logitech speakers is way better than any monitor speaker
how about amazon basics are they a good brand?
I like their cables don't know about speakers
The thing with Amazon basics that's great is you get what you pay for
