Desktop benching:
https://linustechtips.com/topic/1082154-first-build-check/#findComment-12718233
PCPartPicker Part List
CPU: AMD - Ryzen 5 1600 3.2 GHz 6-Core Processor  ($104.89 @ OutletPC)
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard  ($74.99 @ Amazon)
Memory: Team - Vulcan 8 GB (2 x 4 GB) DDR4-3000 Memory  ($37.89 @ OutletPC)
Storage: Team - GX2 512 GB 2.5" Solid State Drive  ($47.99 @ Amazon)
Video Card: PowerColor - Radeon RX 570 4 GB RED DRAGON Video Card  ($119.99 @ Newegg)
Case: Cooler Master - MasterBox Q300L MicroATX Mini Tower Case  ($42.00 @ B&H)
Power Supply: Corsair - CX (2017) 450 W 80+ Bronze Certified ATX Power Supply  ($40.50 @ Newegg)
Total: $468.25
Generated by PCPartPicker 2019-07-14 06:41 EDT-0400
Much better build.
I can spec down the case to save some money, i assumed 450$ budget.
Also stop by microcenter to get a deal on first gen
https://linustechtips.com/topic/1082154-first-build-check/#findComment-12718235
Total: $468.25
Much better build.
Ah, alright. Thanks, but I think I'm fine with the build I have now, as long as it runs OK. I definitely don't play crazy games ?. Do you think my orgional parts list will work(as in all be compatible etc)?
https://linustechtips.com/topic/1082154-first-build-check/#findComment-12718241
It will work just fine. Its just will be significantly slower in games.
Case: Aerocool - Aero-300 FAW ATX Mid Tower Case  ($29.99 @ Newegg Business)
Total: $456.24
Generated by PCPartPicker 2019-07-14 06:59 EDT-0400
If you can muster the littke extra, it wil. Definitvly be worth it.
https://linustechtips.com/topic/1082154-first-build-check/#findComment-12718254
33 minutes ago, BobThePCMaker said:
Hi, updated my build list, could someone look through it for me, and check it's definitely compatible. Thanks! ?
https://pcpartpicker.com/user/BobThePCBuilder25/saved/#view=GM8PnQ
I'll recommend something like this..
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard  ($64.99 @ Newegg)
Total: $446.24
Generated by PCPartPicker 2019-07-14 07:04 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1082154-first-build-check/#findComment-12718262
Total: $456.24
B450 pro4 atx board is currently $10 cheaper than the board that you have listed above...
https://pcpartpicker.com/product/PCKcCJ/asrock-b450-pro4-atx-am4-motherboard-b450-pro4
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1082154-first-build-check/#findComment-12718263
Total: $446.24
basically the same as @GoldenLag's suggestion lmao, this one is the best for $450 imo. 2200g's integrated GPU is like barely a GT 1030, while the RX 570 is like a GTX 1060 3GB
https://linustechtips.com/topic/1082154-first-build-check/#findComment-12718264
Total: $446.24
Thats literally a copy of the build i put out. Except with Mail in rebates enabled........
https://linustechtips.com/topic/1082154-first-build-check/#findComment-12718265
Cheaper mobo
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1082154-first-build-check/#findComment-12718269
Thats with mail in rebates.......
Nvm
Edit: k dont use rebates since they are fundamentally dumb.
https://linustechtips.com/topic/1082154-first-build-check/#findComment-12718271
