Alrighty, according to the manual, PCIe slot 3 shares the lanes with the dedicated m.2 slot on the motherboard. Am I able though to hook up another M.2 drive on the PCIe Slot 3? Like have an NVMe drive plugged into the m.2 slot and install another one via adapter into the actual PCIe slot 3 and run them simultaneously, because after all, it has 16 lanes and one NVMe only takes up 4 lanes, so it should work right? Or is there a protocol that prevents me from running more than one over it?
640294663_SmartSelect_20190707-182205_AdobeAcrobat.thumb.jpg.07d5153caecd023c31c8cd5aab73a3b9.jpg
https://linustechtips.com/topic/1081737-x99-nvme-help/
Nvme connection is only on PCIe Gen 3.4.
The Nvme slots.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1081737-x99-nvme-help/#findComment-12715373
If I remember correctly, you can only use one or the other, but not both. If you are using the dedicated M.2 slot that shares with PCIe slot 3, then the PCI slot is rendered useless.
You might be able to connect hardware to it, but don't be surprised if it is flaky at best. This is generally not advised.
My Rig:
Asus Strix Z270e Gaming MB | Intel Core i7 7700k | Cooler Master Hyper 212 EVO | 32GB Crucial Vengeance |
NVidia RTX 2080TI Founders Edition | WD Black 512GB NVMe; Samsung 512GB 850 EVO SSD; 1 TB WD Blue |
Asus ROG PG278Q 144Hz GSync 1440p monitor; ViewSonic VA2231w-LED | Core X5 Tempered Glass Edition Case
https://linustechtips.com/topic/1081737-x99-nvme-help/#findComment-12715533
But it's a fucking 16 lanes slot, for what do I have 40 lanes if a single m.2 slot uses up 16 lanes where it should only use 4 :(
https://linustechtips.com/topic/1081737-x99-nvme-help/#findComment-12715933
Dies this diagram help you understand it? I have trouble seeing through this.
7887_22_asus-x99-deluxe-ii-motherboard-review_full.png.5980459f186adc41770e103e02fceb63.png
But what exactly does q switch mean, apparently it shows what you said, that when there is something plugged into the m.2 slot and u.2, it'll drop down to x8 on the PCIe slot itself.
Because there are 2 modes on this board, 2 way SLI or 3 way SLI, does that refer to 2 way SLI?
https://linustechtips.com/topic/1081737-x99-nvme-help/#findComment-12716008
