I'm trying to mount 3 monitors onto my desk with clamps.
I have two 24 inch monitors and one 27 inch monitor.
I'd like to set them up with the 27 inch in the middle and the 24 inch on the sides
I was wondering:
if it'd be best to buy dual arm mount and one single arm mount and put my 24 and 27 inch on the dual and the other 24 inch on the single arm
-or-
if I should buy single arm mounts for all three?
https://linustechtips.com/topic/1081608-vesa-mount-setup-thoughts/
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
From my personal experience, I'd go with three single mounts. Its just more flexible,. And  I suppose you could simply put multiple single mounting arms on the same "tube" you screw onto your desk, so you have the best of both. Depends on what quality you go for. Word of advice: don't cheap out on the mount for the 27". Mine is a tiiiny bit too weak to comfortly hold it in position, so every time I adjust the screen (I have a 27" and 23" mounted above each other) - it's a balancing game to keep it from sagging down again -.-
"We cannot change the cards we're dealt - just how we play the hand" - R. Pausch
CPU: Ryzen 7 3700X , Cooler: BeQuiet Dark Rock 3 Motherboard: MSI B450 Mortar Titanium RAM: 16 GB Corsair LPX 3200 GPU: EVGA RTX2070 XC Storage: Adata 120GB SSD, SanDisk 1TB SDD, 2TB WD GreenHDD Case: Fractal Design Define Mini C PSU: EVGA Supernova 650GS Peripherals: Master Keys Pro S, Logitech G402 Audio: Schiit Fulla 2 + Sennheiser HD 650. Laptop: Asus Zenbook UX 302
17 minutes ago, jstudrawa said:
It's a bit unruly for me and a bit pricey. But looking at it now it is tempting.
Do you have any recommendations for a good single mount?
I was initially looking at this
https://www.amazon.com/VIVO-Monitor-Adjustable-Articulating-STAND-V001/dp/B00B21TLQU/ref=sr_1_4?gclid=EAIaIQobChMIvM6y0o2w4wIVhJ6fCh2H5gtHEAAYASAAEgJdLPD_BwE&hvadid=345209627688&hvdev=c&hvlocphy=9007299&hvnetw=g&hvpos=1t1&hvqmt=e&hvrand=5452135823960638364&hvtargid=kwd-11213992&hydadcr=24665_10401006&keywords=vesa+mount&qid=1562959458&s=gateway&sr=8-4
Unfortunately, I don't since I haven't looked into any replacements yet. But I suppose you're better off going with a fixed mount like the one you linked instead of something with springs. You lose the ability to height adjust, but you also avoiding unintended height adjustments caused by gravity :D
1 hour ago, celerystruct said:
Thanks for considering our mount!  The one in the link has some limits to how far it can be pushed back, so it may present some difficulty if your desk isn't too deep.  We have a newer model with an arm that's able to fold back on itself: https://www.amazon.com/gp/product/B074G56JCQ
Or if you have plenty of room to work, we have a triple mount large enough to support the monitors with the sides curved in to a comfortable position: https://www.amazon.com/gp/product/B0798K58B4
The arms are very long though, so the single mounts may be a better option if you don't have a lot of room to work.
On 7/12/2019 at 3:43 PM, jstudrawa said:
It's a bit unruly for me. I don't have much space behind the desk as it is pushed right up against the wall. Also for flexibility so that if I buy a bigger monitor or an ultrawide I can just swap out the one instead of potentially the whole thing.
