Hi Guys,
I picked up a Sony Xperia SP a month ago (really like it) But my wifi keeps disconnecting after 10 seconds! When I go in to the options my wifi is just there with 2/4 bars and need to reconnect.
This really bothers me.
Hope you guys can help.
Thanks in advance
https://linustechtips.com/topic/108159-wifi-keeps-disconecting/
Does is happen on different networks or just the single one you were referring to?
CPU: i5 4670k • Cooler: Corsair H100i • Motherboard: MSI Z87 MPOWER • RAM: Crucial Ballistix Elite 2x 8GB • Storage: Samsung 840 250GB SSD, 2x WD Red 3TB • GPU: EVGA GTX 780 3GB • PSU: Corsair RM750W • Case: Corsair 750D • Mouse: Razer Naga 2012 (I actually use the thing for productivity/media buttons) • Keyboard: Ducky Shine 3 w/ Browns - Green LED • Monitor: Asus PB278Q 27" 2560 x 1440, ASUS PB238Q 23" 1920x1080 • Lighting: 2m NZXT Sleeved Blue LED Strip • pcpartpicker.com/p/3cHfZ
https://linustechtips.com/topic/108159-wifi-keeps-disconecting/#findComment-1445813
After time more in my network, but sometimes at school too
I don't know if this is standard, but there is sometimes a wifi option to "disconnect weak connections" or something like that. Try setting that to off and see if it helps.
https://linustechtips.com/topic/108159-wifi-keeps-disconecting/#findComment-1445830
Sadly it was allready disabled, thanks for the help though.
https://linustechtips.com/topic/108159-wifi-keeps-disconecting/#findComment-1445924
Are you running 4.3+? when I updated to 4.3 on my Galaxy S3 I had the same issue, go to Settings>Wifi>Advanced> and make sure something like Auto Network Switch is off.
DCyNjpf.png?1
Gaming Rig - Excalibur - CPU: i5 6600k @ 4.1GHz, CPU Cooler: Hyper 212 Evo, Mobo: MSI Gaming M3 RAM: 16GB Corsair @2400MHz, GPU: EVGA 1060, Case: NZXT Phantom Full Tower (Red)
My Virtualization Server - Dell R710: 2x X5570s @ 2.93GHz with 32GB DDR3 RAM [Web Server, OSX, Plex, Reverse Proxy]
I love computers, gaming, coding, and photography! Be sure to quote me so I can respond to your post!
https://linustechtips.com/topic/108159-wifi-keeps-disconecting/#findComment-1446419
DCyNjpf.png?1
Thanks, but sadly I cant find the option on my Xperia SP
https://linustechtips.com/topic/108159-wifi-keeps-disconecting/#findComment-1446534
Found this on xda developers:
http://forum.xda-developers.com/showthread.php?t=2372006
Someone from sony said this on a thread on there forums:
There's no setting in the phone that increases the wifi range but you could try changing the settings in your router and see if that helps. Start by checking what channel is best to use using this app and then set your router to that channel: https://play.google.com/store/apps/details?id=com.farproc.wifi.analyzer.
If your router supports both 2.4 and 5GHz, try connecting to the SSID for 2.4GHz instead. 5GHz gives a shorter range.
https://linustechtips.com/topic/108159-wifi-keeps-disconecting/#findComment-1446537
Thanks again, I try it tomorrow, watching Football now and can't get the the router atm without waking up my parents, i'll let you know the result tomorrow, thanks again!
https://linustechtips.com/topic/108159-wifi-keeps-disconecting/#findComment-1446544
No problem.
https://linustechtips.com/topic/108159-wifi-keeps-disconecting/#findComment-1446546
:D
Did it work? Just wondering.
https://linustechtips.com/topic/108159-wifi-keeps-disconecting/#findComment-1464443
