so i have cyanogenmod 10.2.0 on my htc evo lte on sprint. when i send a group message or mms to someone it says its sending, but it never says sent, but it does send. how do i get it to tell me if it sent for sure or if there really is an unsendable error,
thanks in advance
STEAM NAME: JewishBacon GPU  Sapphire dual x R9 280x OC edition CPU core i7 4770k stock speed COOLER H100i  CASE Fractal R4 Window Black  MOBO MSI gd-65 gaming Storage 1TB WD Blue drive, 1TB Samsung 7200 rpm, 120 GB OCZ SSD, 64 GB WD Blue ssd  RAM 12 GB @ 1600 Ghz kingston RAM  MiscNZXT HUE, disk read/write, 2x 21 inch 1920x1080 monitors
https://linustechtips.com/topic/108156-cyanogenmod-mms-error/
You could always try GoSMS.
MOBO - Asus Sabertooth 990FX R2.0   CPU - AMD Phenom II X6 1055T @ 3.5GHz - Corsair H80i   RAM - 2x Corsair Vengence 4GB DDR3 @ 1666 MHz
GPU - SAPPHIRE 100362-3L Radeon R9 290 4GB Tri-X OC  Sound - ASUS Xonar DSX  PSU - Thermaltake SMART M Series SP-850M 850W
https://linustechtips.com/topic/108156-cyanogenmod-mms-error/#findComment-1445876
ads? is the 4.99 to make them go away a 1 time thing?
https://linustechtips.com/topic/108156-cyanogenmod-mms-error/#findComment-1446519
you gotta have mobile data on and make sure you carrier's apn settings are correct. i can't get it to work on android, but it works on ios for me.
Delltopia
Case & Mobo: Stock Dell Optiplex 7010, CPU: i5 3470, RAM: 16gb 1333 DDR3 (1x8gb Corsair Vengence, 2x4gb Random), GPU: Diamond Radeon HD 7970,
PSU: EVGA GQ 650W, SSD: Kingston v300 128gb (OS), HDD: 700gb Seagate 7200rpm (Storage)
https://linustechtips.com/topic/108156-cyanogenmod-mms-error/#findComment-1449392
