Hey guys, I was just wondering what aftermarket solution I could get for my R9 290X, considering there is no ETA on the Kraken G10 Bracket, what other options are are there?
Thanks!
CPU: Intel Core i7 4790K @ 4.7GHz, 1.3v with Corsair H100i - Motherboard: MSI MPOWER Z97 MAX AC - RAM: 2x4GB G.Skill Ares @ 2133 - GPU1: Sapphire Radeon R9-290X BF4 Edition with NZXT Kraken G10 with a Corsair H55 AIO @ 1140/1650 GPU2: PowerColor Radeon R9-290X OC Edition with NZXT Kraken G10 with a Corsair H55 AIO @ 1140/1650 - SSD: 256GB OCZ Agility 4 - HDD: 1TB Samsung HD103SJ- PSU: SuperFlower Leadex GOLD 1300w  - Case: NZXT Switch 810 (White) - Case fans: NZXT Blue LED Fans- Keyboard: Steelseries Apex Gaming Keyboard - Mouse: Logitech G600 - Heaphones: Logitech G930 - Monitors: ASUS PB287Q and Acer G246HYLbd -  Phone: Sony Xperia Z1
https://linustechtips.com/topic/108129-r9-290x-cooling/
You could start by letting me hug the crap out of that dog in your profile pic!
I'll be paying attention to this thread as I'm getting ready to do a custom water cooling setup. Will be overkilling with pink :D
8320 @ 4.3ghz l Gigabyte 970a Ud3 l Hyper 212 Evo l R9 290 l 8gb RAM 1866 Vengeance l 1tb WD Black l 120gb Samsung Evo SSD l HX750 Gold PSU l 500d Arctic Case l Windows 8 OS l K65 and Blackwidow Keyboard l M65 and DeathAdder 2013 l Qck Steelseries l 24in Vizio Monitor 1080p
https://linustechtips.com/topic/108129-r9-290x-cooling/#findComment-1445533
I'm personally going with a RayStorm 750 EX280, EK-FC R9-290x, some tubing, and a few extra fittings. Because the EX280 is a thin radiator and only 280mm, I might get another 120-240mm radiator, depending on the temps I'm getting.
Intel i5 6600k~Asus Maximus VIII Hero~G.Skill Ripjaws 4 Series 8GB DDR4-3200 CL-16~Sapphire Radeon R9 Fury Tri-X~Phanteks Enthoo Pro M~Sandisk Extreme Pro 480GB~SeaSonic Snow Silent 750~BenQ XL2730Z QHD 144Hz FreeSync~Cooler Master Seidon 240M~Varmilo VA87M (Cherry MX Brown)~Corsair Vengeance M95~Oppo PM-3~Windows 10 Pro~http://pcpartpicker.com/p/ynmBnQ
https://linustechtips.com/topic/108129-r9-290x-cooling/#findComment-1445585
Gigabyte, MSI, Asus, Sapphire and XFX have aftermarket coolers. You can also get a water block and a custom loop but a non-ref card would be better imo.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/108129-r9-290x-cooling/#findComment-1460422
I think GELID has an aftermarket cooler that can fit into a 290X if you're looking to buy the reference model and strip it of the standard cooler.
http://www.gelidsolutions.com/products/index.php?lid=1&cid=17&id=52
Its terrible. does not fit across the VRM's properly causing them to heat up past there 125c limits.
Quack 🦆
https://linustechtips.com/topic/108129-r9-290x-cooling/#findComment-1460484
I don't use them but http://www.overclockers.co.uk/showproduct.php?prodid=HS-008-NX has the G10, guessing they ship to wales.
Also the Arctic Cooling Accelero Xtreme III is a fantastic cooler. Have one on my 290x. Check the sig link for more info chap.
AMD Ryzen 5900x, Nvidia RTX 3080 (MSI Gaming X-trio), ASrock X570 Extreme4, 32GB Corsair Vengeance RGB @ 3200mhz CL16, Corsair MP600 1TB, Intel 660P 1TB, Corsair HX1000, Corsair 680x, Corsair H100i Platinum
https://linustechtips.com/topic/108129-r9-290x-cooling/#findComment-1460510
