System specs
Msi Z170A pro mate
XFX rx 580 8gb
Corsair TX550m
Patriot - Signature Line 16GB (2 x 8 GB) DDR4-2133
I had an I5 6500(non-k). I had the Ram set to 14-15-15-40 @1.25v running stable at 2533mhz. Been like this for a couple of years.
I was gifted an I7 6700(non-k). I swapped it in and started having problems with games.  Everything would crash. Usually in a few minutes. AMD software would reset itself.  At first I thought I knocked something loose I reseated the graphics card. tried DDU and reinstall software nothing worked. I even tried a different RX 580.
I finally did what I should have done from the beginning  I pulled the cmos battery. Restarted, and now everything seems to work.
Here's the question. The only thing that I ever changed in the bios was the ram. I want to retry overclocking the ram. Could that be the problem though? The I7 came from a system that I helped diagnose. It had a stick of ram that went bad. (It was a Dell, no changes in ram settings) could this CPU have issues with ram? I don't want to kill my ram.
https://linustechtips.com/topic/1081284-problems-after-cpu-change/
Unlikely, whenever you swap a CPU or any big ticket components a bios update/reset is usually needed and ram overclocking is affected by the CPU so changing that could of just messed up the overclock.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
Ok thanks.
