up your bitrate a bit. I run mine at 5000 at 720/60 myself and have no pixelation. The most cause is from lack of bitrate, but watch your CPU usage as you up your bitrate, your CPU usage will go up as well. You also will likely need to lock your FPS as there is a GPU allocation bug with OBS that when you get 90% or above utilization OBS is the red headed step child and starts dropping FPS from 60 down to compensate from not being able to render the frames.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1081011-streamlabsobs-settings/#findComment-12709574
