Manjaro login problem
Go to solution Solved by Oalei,
13 minutes ago, Sauron said:
I can't know if I don't see the message. Maybe try again and film it so you can freeze frame on the error.
You know what fuck it, it's always been like that before anyway and have no problems. It's unmounting something, I'm tired already missed it too many times.
Try entering your username (when it says login) and then password, then show what happens. I ran into this before, and it usually is an easy fix (usually ending either in reinstalling your Desktop Environment, or the whole OS (tho it is unlikely reinstalling the OS is needed)). If you need to reinstall your Desktop Environment, no problem with your other files (they will be fine)
https://linustechtips.com/topic/1081008-manjaro-login-problem/#findComment-12709518
I forgot my username I think. Well this is stupid.
Login incorrect.
https://linustechtips.com/topic/1081008-manjaro-login-problem/#findComment-12709523
Login incorrect.
Well that is a rip.
Not all is lost, try this
put root all lowercase for Login and put in the password when you use Sudo commands. That also means when installing the desktop environment again you wont have to do "sudo ___" every time
https://linustechtips.com/topic/1081008-manjaro-login-problem/#findComment-12709525
Well that is a rip.
IDK a single thing you're talking about,  I'm using manjaro for pure gaming on steam and web browsing. I literally don't know a single thing about Linux except alsamixer.
https://linustechtips.com/topic/1081008-manjaro-login-problem/#findComment-12709531
Okay, uh basically on login type "root"
then use the password you use to install applications (like chrome and steam)
https://linustechtips.com/topic/1081008-manjaro-login-problem/#findComment-12709534
2 minutes ago, Oalei said:
As long as I don't have to reinstall everything. I'm a freaking casual dude IDK the difference.
Quote
sudo pacman -S plasma kio-extras
Run the command above (if asked enter admin password). This will give you KDE plasma which is one of many environments to use. Nothing should have to be reinstalled after this
https://linustechtips.com/topic/1081008-manjaro-login-problem/#findComment-12709562
So what do I choose? Maybe just enter?
https://linustechtips.com/topic/1081008-manjaro-login-problem/#findComment-12709571
Infinite failed retrieving files and Errors.
Uhhhhhh... wtf... So I never seen Manjaro fail to find those files before. Enter the command again and before you hit enter show me what you see. If this fails again we can luckily just keep throwing desktop environments at it until it works.
https://linustechtips.com/topic/1081008-manjaro-login-problem/#findComment-12709578
Well there is 2. Maybe I should've just press 1 for default.
Don't mind my beautiful face pls.
https://linustechtips.com/topic/1081008-manjaro-login-problem/#findComment-12709586
Same problem, maybe connect to internet?
https://linustechtips.com/topic/1081008-manjaro-login-problem/#findComment-12709594
