Hey folks.
I recently kicked off a thread here regarding getting some advice on a build.
As suggested I waited for the parts to come out and I've landed on a new list of parts that I'd love to get more feedback on before I go ahead with the purchase. Thanks in advance!
https://linustechtips.com/topic/1080896-build-advice-v2/
Change the hard drive to a 7200 RPM model, maybe the Toshiba X300.
Everything else is fine!
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/1080896-build-advice-v2/#findComment-12708739
Just now, EAK said:
Awesome thanks, one quick question I forgot to ask. How much of a benefit is going with the be quite cooler going to be over the stock cooler that comes with the CPU.
Are you looking to overclock? Then yes, you can get a bit higher clock.
Otherwise? No.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/1080896-build-advice-v2/#findComment-12708751
