When I overclocked my laptop screen to 90hz the colors started to look weird. Mostly the blues would look old comic book print. When i looked at my display setting, it showed that the Bit Depth for Display 1 was 6-bit instead of 8-bit on normal setting. How do i change the bit depth to 8bit while keeping my 90hz refresh rate?
you're maxing out the transfer rate of whatever display connection you're on. You can't do what you asked for.
Desktop benching:
