silent wings 3 Need help choosing case fans :)
4 hours ago, D1Wolfgang said:Some 10 dollar Cooler Master fans. ill link. https://www.amazon.com/gp/product/B0026ZPFCK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Btw, they say they run at 19 dB, but that doesn't seem right, that means my new fans would be just as loud uh oh.
And idk, it was some random guy that said the frequency the fans hummed at is a frequency known to make people more irritable. lol. maybe a troll.
My CPU is obviously occupied, and the 3 Chassis Fan spots would be, so where would I plug my other fan into?
Wouldn't that be where a 3 or 4 pin to molex adapter help?
https://www.amazon.com/SilverStone-System-Cables-Black-CPF04/dp/B00VNW556I#customerReviews
Sickleflows are mediocre at best and are a good example of bull specs or at least specs not being reliable for comparisons between manufacturers. There's little to no regulation on how they're measured so I highly recommend sticking with reviews and in-depth benchmarks instead.
The aio_pump and w_pump headers can be used as normal fan headers.
You linked a pwm hub which acts as a powered splitter and would be good if you need to split a pwm signal to more fans. When '3-4pin fan to molex adapter' is mentioned, it's generally just for power at 100% rpm. The first 2pins are ground and 12v and any 3rd and 4th pin are generally just dummies. Like this:
