Need insight regarding gpu and igpu
Go to solution Solved by Slottr,
Depends what cpu youre regarding
Some have IG, But not many. If it's one of the many that don't, then no you can't output from your motherboard
6 minutes ago, Ninynine said:
I am planning to upgrade my cpu to a xeon. So my question is, does the vga port on my mobo would still output a video? I have a discrete graphics card installed, i'm planning to have a dual monitor setup.
XEON never has iGPU
