Killer WiFi problems
Solved by kirashi,
31 minutes ago, juice_boxer said:Yes my other devices get good speeds and this laptop is the only not, I am connected to a 2.4ghz WiFi not Ethernet.
You'll want to connect to the 5GHz network then re-test. Although 2.4GHz is capable of getting around 50-60mbps when you're close to the router, 5GHz is required to attain speeds higher than this maximum due to it being the WiFi frequency capable of doing such things.
