So im planning on building a great gaming pc and i want help with compatibilty (if the parts are compatible or not)
Here are the parts:
-cpu: intel core i9-9900k
-cpu cooler: ausus rog ryujin 240 rgb
-motherboard: ausus rog maximus xi hero (wifi)
-memory: trident z rgb 64gb
-storage: -samsung ssd 860 evo 4tb
                 -samsung ssd 970 evo plus 2tb
-graphics card: gigabyte aorus geforce rtx 2080ti xtreme (i completly messed up the name)
-case: corsair spec omega rgb black
-power supply: corsair rmx 850 80+ gold
-operating system: windows 10 pro 64 bit
-monitor: acer preditor x34 120 hz
https://linustechtips.com/topic/1078696-looking-for-compatibility-help/
They're compatible yes, but why don't you wait for the new Ryzen to launch? you'll only wait for a bit and you don't have to go AMD you just won't regret choosing the wrong platform later, especially considering the price difference while not loosing much performance, if any!
Why a 4TB and 2TB SSD?
Why 64GB of RAM?
Why the 9900K now with Ryzen 2 three days away?
Even if you don't go Ryzen at least wait to see the performance difference and choose then after benchmarks are out
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
21 minutes ago, Wail.M said:
Hey the 4tb ssd is for backup
if it's backup.... why is it an ssd
and 64gb cus there is no 48gb kit
if you can find a video game that uses half of that ram i'll eat my hat
