So first off let me state that i only put about an hour and thirty minutes into building this, sorry for the terrible cable management.
The Parts:
Intel Core i5-3570K
Corsair H100I - 2 Stock fans
ASUS P8Z77-V Motherboard
8GB of Corsair Vengeance Black 2x4GB 1600Mhz Memory
Sapphire R9 280X-DualX OC Edition Card 3GB VRAM
Corsair TX850M Power Supply Unit, Overkill i know, It was lying around.
Cooler Master Storm Stryker White
Kingston V300 SSDNOW 120GB OS drive.
To be added:
512GB Samsung 840 EVO - Storage Drive
Replace R9 280X with R9 290X.
I think the hardest part about this case, is the way that they routed the cables into the motherboard area, I found it especially difficult to get the Front header's aligned correctly as they were tied up with other cables of the fan controller. I do apologize for terrible picture quality, i do not currently owns camera and was using my iPod Touch 5.
This system will be my current workstation that will travel with me to and from work, and throughout school everyday. I plan to exclusively use SSD's because it will be transported so much. I also plan to paint the case black when summer comes.
Picture time!
Thanks for taking a look!
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
https://linustechtips.com/topic/107857-work-rig/
yay pictures
Specs
https://linustechtips.com/topic/107857-work-rig/#findComment-1441836
looks good to me.
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/107857-work-rig/#findComment-1441875
Nice rig! cable management actually isn't too bad.  The only recommendation I have it to route the power, reset, etc. under the motherboard.
PS: Photos are sideways
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/107857-work-rig/#findComment-1442026
That is a HUGE case to transport. Wouldn't something like a Prodigy be easier to transport?
I'm 6'5, i can also lift about 100 pounds per arm, "Hardly" is a loose statement in this case.
https://linustechtips.com/topic/107857-work-rig/#findComment-1442221
