Posted July 3, 2019 hi , do anyone know how to fix the high idling temp ? my spec are i5 9600k 4.9 on 1.3v (current setting) aorus z390 elite gtx 1080 ti aorus xtreme dram 16gb 3200mhz cpu cooling cryorig quadlumi h7 ambient temp around 33 C measured by using infrared thermometer fan layout are 3 intake from front and 2 exhaust on top and 1 exhaust from behind the case case cooler master mb510l thanks Link to comment https://linustechtips.com/topic/1078267-help-idling-temp-please/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 3, 2019 What cooler are you using? Legit the most important factor to temperature ..... Also a what is you current case fan layout. Magical Pineapples
