Hello, so long story short I have been PC gaming for just over a year and a half now. When I built my first gaming PC I had a i5-8400 and what I noticed from the start was my CPU was always running at 100% even when the PC was first booted up. I decided not to long ago to upgrade my processor and motherboard so now I have a i7-7700k. Thinking this would fix my problem I booted into windows and low and behold my CPU usage was still at 100% all the time! I have tried to look up fixes to this problem however I have had no luck. I will post a screenshot in this thread to show you guys what exactly it looks like. Any help would be appreciated :)
https://linustechtips.com/topic/1078100-cpu-always-running-at-100/
Well for one.. 56% is being used by windows defender smart screen.. that doesn’t sound right at all.
it also seems you have heaps of background processes running. Do you need all these running or can you terminate a few?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
This happened on my wifes laptop and it was windows update causing the cpu to be at 100%. Idk if this is your situation or not but I’d go in to settings/update and check for a update
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Pny 5070ti
Fractal Ion 2+ 860watt platinum
Thermaltake View 380
AW2725DF 1440p 360hz oled
Aoc Q27G3XMN mini led
Ps5 Pro
Series X
