Hey guys,
So I've been trying to set a RAID array with 2 patriot memory inferno 60GBs.
As the Z87 chipset is flaky with SF-1222 Controllers, I have to use the 2 ASMedia controlled ports on my board. Now when I installed the latest driver from MSi website, I A. don't know how to access it so I can set up the array, and B. for some reason in device manager it's in the "IDE ATA/ATAPI controllers". The driver manual says it should be in the "SCSI/RAID controllers". I'm on my iPad right now so when I get on my PC I'll post a clip of the manual.
So basically, it says the system is in ATA mode when I want it in RAID mode. Is there a way to change it?
Here is the clip, as promised of how to know what mode your system is running in:
5.from the device manager, look for an named "SCSI/RAID controllers"
-If this entry is present, expand and look for the following controller(s):
  -ASMedia 106x SATA controller
-If the controller above is not show then your system is not running in RAID mode
6.from the device manager, look for an entry named "IDE ATA/ATAPI controllers"
-If this entry is present, expand and look for the following controllers:
  -ASMedia 106x SATA controller (This one is the one I have, I want to switch it to RAID mode.)
EDIT: Anyone know anything?
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
https://linustechtips.com/topic/107803-help-with-asmedia-sata-controllers/
