I am building a new gaming rig and I want to give Ryzen a chance. So I have a list of things im salvaging from other PC's
1. GPU
2  Power Supply
3. Sound Card
4. 12gb of ram ddr4
5. hdd and ssd
so here is my question the ryzen 7 2700  or wait to get the ryzen 5 3600 because they are going to be the same price for the processors.
I heard that the ryzen 5 3600 is going to be up there with the i7 8700k in preformance wise plus i have to save up the money anyway im at $128 USD and a budget of 450
i just need a case, Motherboard, and CPU and a water cooler 120mm
the system im building is a full atx system
Corsair 5000d Airflow
Corsair 360mm H150i AIO
Corsair HX1000i PSU
Gigabyte X570 WIFI Board
Ryzen 9 3900X
16Gb Corsair Vengeance DDR4 RAM
2080 FE
Windows 11 Home
https://linustechtips.com/topic/1077902-new-build-help/
just rumours
2  Power Supply
I wont get used PSUs, that's as risky as sharing syringes for injection
waste of money, might as well go air cooling
Desktop benching:
https://linustechtips.com/topic/1077902-new-build-help/#findComment-12686477
PSU is Brand New i had to replace the one in this current machine that is barely clinging to life
Corsair HX1000i PSU
Ryzen 9 3900X
2080 FE
Windows 11 Home
https://linustechtips.com/topic/1077902-new-build-help/#findComment-12686479
Definitely go with the Ryzen 5 3600. Not only is it newer, it also preforms better. The only place it under preforms (compared to the Ryzen 7 2700) is in multi-core performance, only because the Ryzen 5 3600 has only 6 cores, while the Ryzen 7 2700 has 8 cores. Hope this helps!
https://linustechtips.com/topic/1077902-new-build-help/#findComment-12686489
the nvme ssd has my windows install on it windows 10 64 bit and the hdd is a 1tb segate 2.5 inch i bought not to long ago for my laptop which hit the dust
i just done some reading and i think im going wait until the release of 3rd gen ryzen to see how much a motherboard cost for x570 because im being told on one end that its going to be 150 and one saying 1000 USD
Corsair HX1000i PSU
Ryzen 9 3900X
2080 FE
Windows 11 Home
https://linustechtips.com/topic/1077902-new-build-help/#findComment-12686492
20 minutes ago, dgsddfgdfhgs said:
little strange combination.
ryzen loves loves fast ram (3000mhz+) & dual channel
yeah i could only afford a 4gb stick and then i got an 8gb stick
i just found a single 16gb stick for 69 dollars 3200 mhz
Corsair HX1000i PSU
Ryzen 9 3900X
2080 FE
Windows 11 Home
https://linustechtips.com/topic/1077902-new-build-help/#findComment-12686495
Get 2x8GB sticks, else you're loosing out on quiet a bit of gaming performance.
3200Mhz 16GB (2x8GB) T-Force Vulcan for $67
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
https://linustechtips.com/topic/1077902-new-build-help/#findComment-12686640
Edit: I found the same board in an x470 chipset for 20 dollars more
Ryzen 7 2700 -209
corsair carbide 100r - 50
Gigabyte Aorus Ultra Gaming x470 -128
new ram - 70
about 430 USD for this build
Corsair HX1000i PSU
Ryzen 9 3900X
2080 FE
Windows 11 Home
https://linustechtips.com/topic/1077902-new-build-help/#findComment-12688391
