i recently finishef building a ryzen gaming pc but when i finished putting everything in place and i turn it on the fan spin and case led lights is on but no display.
MOBO: MSI A320M PRO-VH PLUS
CPU: Ryzen 5 1600
RAM: Crucial DDR4 8GB 2133MHZ
GPU: GIGABYTE AORUS GTX 1660 TI 6GB
PSU: SMART POWER 400W 8+ BRONZE
CASE: Cooler Master MB520 RGB
Ps: when i turn the pc on the ez debug led indicate solid white in dram and i tried turning on the pc without ram but nothing changed still solid white in dram debug Led
please help
https://linustechtips.com/topic/1077670-ryzen-build-issue/
how many sticks and in which slot did you put it in?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1077670-ryzen-build-issue/#findComment-12684635
Try moving the memory stick to the other port. Check power cables and put a little pressure on each to check if they click. Alternatively try booting without the graphics card installed.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1077670-ryzen-build-issue/#findComment-12684727
Right so, it turns on but nothing happens.
It doesn't even power cycle a couple times, as in it turns itsself off a couple of times?
Next to the memory slots and 24 pin powerconnector is a debug led. Can you tell us which leds are burning?
Gamesystem: X3700, 32GB memory @3200mhz, GTX1080 Hybrid
Unraid system: Epyc 7352, 24/48, 96GB ECC buffered @2666mhz, 2x GT710, GTX1050Ti
https://linustechtips.com/topic/1077670-ryzen-build-issue/#findComment-12684730
the dram light is on all te time even when i booted without ram
https://linustechtips.com/topic/1077670-ryzen-build-issue/#findComment-12684786
Sounds like a defective RAM stick, or not properly plugged in. either or.
Do you have the option to test with another stick? Any size (capacity, not generation) will do.
https://linustechtips.com/topic/1077670-ryzen-build-issue/#findComment-12684801
the cpu doesn't have onboard gpu but just to make sure i tried that but nothing happend the dram debug led is continuously on
https://linustechtips.com/topic/1077670-ryzen-build-issue/#findComment-12684806
Can we see the top too? meaning the top of the mainboard.
https://linustechtips.com/topic/1077670-ryzen-build-issue/#findComment-12684818
To add. Have you tried to let the computer try to 'learn' the memory? It can take a while.
Just leave the computer on and do its thing, think maybe 10 minutes should do the trick?
https://linustechtips.com/topic/1077670-ryzen-build-issue/#findComment-12684836
11 minutes ago, sahlhrahou said:
Thank you, everything looks connected properly, so only conclusions i can make are defective memory module, memory slot or simply the mainboard takes a long time to learn the memory.
I think 'default' setting for a ryzen cpu is that it expects 2333mhz memory?
https://linustechtips.com/topic/1077670-ryzen-build-issue/#findComment-12684873
the ram is 8gb DDR4 2133MHZ
https://linustechtips.com/topic/1077670-ryzen-build-issue/#findComment-12684903
yeah, should learn it automatically and boot anyway.
When you first powered it on, did it powercycle on itsself? as in, turn itsself on and off a couple of times?
https://linustechtips.com/topic/1077670-ryzen-build-issue/#findComment-12684914
In case you do not have an extra stick to test with. Try resetting the bios.
Either take the battery out after unplugging the power cable, put it back in after a minute, followed by the power cable. Or put a jumper on the 2 pins jsut above the i of MSI (in picture its titled JBAT1)
https://linustechtips.com/topic/1077670-ryzen-build-issue/#findComment-12684933
i tried that nothing changed
https://linustechtips.com/topic/1077670-ryzen-build-issue/#findComment-12685544
So then either a defective board, defective ram stick or defective powersupply.
https://linustechtips.com/topic/1077670-ryzen-build-issue/#findComment-12686622
  • 2 weeks later...
the problem was with the ram stick , I replaced it and problem solved
The thing is i have a little doubt about my PSU it's a 400w 80+ bronze and its running just fine with no problem, but in the long term will it cause a problem or fry other component??
please help!
https://linustechtips.com/topic/1077670-ryzen-build-issue/#findComment-12711740
please help!
this is hard to answer, as you never have a certainty.
in my life thus far, both using a brand as psu's that came with cases, i've had only 1 psu that malfunctioned in its lifespan. And even then it didn't fry anything else in the case.
The one you have should in theory be able to keep your system up and running without frying anything.
If you do decide to replace it, check this post for advice:
if you really want to spend money tho, i would rather recommend you spend it on a 2nd ram stick for dual channelling.
https://linustechtips.com/topic/1077670-ryzen-build-issue/#findComment-12712462
Since i wanted to replace the ram stick i bought a corsair vengeance DDR4 16gb (8gbx2) 2400mhz
https://linustechtips.com/topic/1077670-ryzen-build-issue/#findComment-12713265
