Does my motherboard support 1gb speed? x470
D1D0T
My new pc has the arous x470 ultra gaming motherboard.In the properties of my network adapter there is an option of 1.0gbps full duplex.but when i apply it my lan stops worrking. I tried running the lan cable through and without the router.I am using cat 6 cables.
What router and other components do you have in the chain?
Sounds like something only has a 100Mbps port and forcing a 1.0Gbps on one end when the other doesn't support 1Gbps will make it stop working until you change it to something both sides support.
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
My rputer is D-Link Dir-816.I tried runnin it directly from lan to pc bypassing the router it doesnt work. As you said it stops working when i change it to 1gbps full duplex but when i change it back to 100 it works.Does my motherboard support such speed? any fixes? i am wasting my package of 200mbps
Well the router only has 100Mbps ports and I suspect the ISP supplied device only has a 100Mbps port as well. You said from the lan to PC, do you mean from your computer to the ISP supplied box or to a switch? If so what model switch?
The board 100% supports gigabit speed
Prior Build Log/PC:
from the wall to the pc. I am not sure if that is what you mean by switch
Does arous x470 ultra gaming  support gigabyte speed ?
When you say from the wall to the PC, you mean the ISP line that comes in?
Either way I'm positive whatever is on the other side only supports 100Mbps. You'll need a new router at the very least to get beyond 100Mbps speed.
Yes, it supports gigabit speed. No motherboards these days, beyond some $5 cheapo ultra low spec boards, only have 100Mbps ports.
Prior Build Log/PC:
Yes directly in the isp line without a router
Then I would do two things:
1 - Get a router with gigabit WAN and LAN ports
2 - Call your ISP, landlord, etc and tell them whatever is on the other side of the wall is only giving you 100Mbps speed and have them fix it.
Prior Build Log/PC:
This router does not support gigabit.  It only supports 10/100.  if you want to be able to connect at gigabit, you will need a new router.  Since it only supports 100Mbps, you are only getting half the speed offered by your ISP (you stated you had the 200Mbps plan).
Yes it has an Intel GbE LAN chip (10/100/1000 Mbit), but it won't work at gigabit speed until you upgrade your router.
