I know transistors and circuits are a thing in CPUs. What other parts are there? What do they do? Thanks!
I lurk
HP Spectre x360 13t late 2019
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Razer Blackwidow Lite
Steelseries Rival 3
https://linustechtips.com/topic/1077004-cpu-parts/
Just now, HedgeSledge said:
Glue to hold the heat shield on.
Solder or thermal paste so that heat transfers from the core to the heat shield.
Gold used for the contact pins / pads.
Thanks. Also, what do the transistors, silicon, and circuits do?
I lurk
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Steelseries Rival 3
https://linustechtips.com/topic/1077004-cpu-parts/#findComment-12679946
Silicon is what they are made out of. Trnsisitors switch, this is what processes 1's & 0's, speed of switching is based on the CPU's clock speed along with other enhancements which make the CPU more efficient at a given clock speed.
https://linustechtips.com/topic/1077004-cpu-parts/#findComment-12679950
Just now, mariushm said:
mosfets
resistors
capacitors (in sram, L1 cache, L2 cache, L3 cache) ... each bit is a capacitor
other fundamental components
Oh, CPUs also have MOSFETS? Cool. And what do resistors, and capacitors actually do though? I'd like the parts and their use if possible.
I lurk
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Steelseries Rival 3
https://linustechtips.com/topic/1077004-cpu-parts/#findComment-12679951
Ohh silicon makes the chip, and transistors make the binary code make sense.
I lurk
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Steelseries Rival 3
https://linustechtips.com/topic/1077004-cpu-parts/#findComment-12679954
Each bit of memory (in caches for example) is basically a super tiny capacitor that either holds a charge (a binary 1) or doesn't (binary 0).
Transistors and mosfets are used to create logic components like AND, NOT, XOR ... and perform operations ... cpu performs operations on bits and bytes and puts results in another place and then does other things with the result and so on...
https://linustechtips.com/topic/1077004-cpu-parts/#findComment-12679955
Okay, thank you!
I lurk
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Steelseries Rival 3
https://linustechtips.com/topic/1077004-cpu-parts/#findComment-12679956
