Some days ago I start have a problem with my pc:
When I start the pc for the first time in the day, it go very slow, ther's a lot of lag in the input and it take like 5 minutes to boot up (with an ssd), this force me to shut down the pc with the case button.
Then when I restart the pc everything goes smooth and nice.
This happen every time I start the pc for the first time in the day.
Any ideas?
Thanks!
https://linustechtips.com/topic/1076600-pc-startup-problem/
Try disabling Fast Boot and CSM in the bios settings.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1076600-pc-startup-problem/#findComment-12676709
1 minute ago, Saksham said:
reset bios. or try go into windows, then click *restart*. dont click shutdown. that could help fix the fast boot.
dont disable fastboot. its kinda nice to have...
If you disable it and re-enable it it should also fix it if that's what's causing the slowness on a cold boot. But if you disable it and test it you can determine if it's the culprit. I wasn't saying to disable it permanently just to see if it helps. CSM you can leave disabled for sure though. I would also check for any firmware updates for the motherboard.
https://linustechtips.com/topic/1076600-pc-startup-problem/#findComment-12676730
Thanks!
Another thing, i dont know if someone can help me,
Recently I've got some problems with Geforce Experience, it keep say that something went wrong with the error 0x0001 and 0x0003, i've tryed everything but only the reinstallation seems work for a few days
I should make another topic?
https://linustechtips.com/topic/1076600-pc-startup-problem/#findComment-12676739
