backup help
Solved by dalekphalm,
5 minutes ago, UrbanFreestyle said:nah the PC is only really on when i need it so that is about 2 hrs (or less) about once a week or so.
Okay, in that case, having a weekly incremental should be fine. You should check what options the software has - you might be able to configure it to automatically shut down the PC after a backup completes. That way you can just leave it running after you use it, let it backup, and then let it shut off by itself.
