Mac OSX 10.7.5 not detecting USB drive
Solved by acwilson96,
dont take this wrong but have you turned it of and on again
I had yeah and don't worry I understand the need for that question. I managed to fix it by attaching a USB splitter to the same USB port and then the Drive to the splitter, odd that this would fix it but whatever!
Featured Topics
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0 -
2
7
1
Shane Martin ·
Posted in Displays2 -
5
INotPablo ·
Posted in CPUs, Motherboards, and Memory2 -
PatRed ·
Posted in New Builds and Planning8
