Is there something as Ethernet controller overheating?
Wolly9102
Hi,
I was working today on my VM's on my main pc. (it was quite hot in the room) I was downloading quite a lot and doing internal transfers between vm's.
After a while I noticed download dropping drastacally. A debian install would take about 12 hours to download. Then I decided to switch over to my laptop which I didn't touch all day and the downloading of debian went fine.
So did the Ethernet chip in my desktop throttle or something? Or does that not exist?
Main PC:
CPU: AMD Ryzen 5 5600X | RAM:Corsair LPX 3200 mhz (16Gb)
Mobo:ASUS Strix B550-F Wifi | GPU: MSI RTX 2070 Gaming Z
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Be Quiet straight Power 10 500 watt
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Samsung 8 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Galaxy A50
What specs?
Seems unlikely but possilbe.
Id do some iperf testing before blaming the network card.
What was the usage on the network card?
6 minutes ago, Electronics Wizardy said:
What specs?
Intel I211
Not much usage. I've noticed it downloaded about 30 mbps and for about 5 seconds and then it stopped downloading . the debian installer said it would take about 12 hours to complete downloading
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Galaxy A50
Every connection over states speed when it starts a large download and it takes a bit for windows to show the correct speed and eta to download finish.
But yes any microchip has a small possibility over overheating
1 hour ago, Wolly9102 said:
Intel I211
30mbs is a very low usage and thats a low power nic
If you want to check for over heating use iperf or a lock network check.
There are many reasons why a debian download would slow other than your nic, and those other reasons like isp throttling, router issues, debian servers throttling, other people on the network are much more likely.
