Lapping really isnt worth it. I did it on 2x Q9550, and a Q6600 in 2008/2009. It took a few degrees off the temps, I will try and find some pictures if I still have them, and the spreadsheet I made wth the differences.
I lapped the heatsinks and CPUs until there was a vacumn formed between them when i pressed the heatsink on the IHS. I didnt use any thermal paste after they were lapped.
It really isnt worth it to be honest. I would get a decent watercooling loop instead.
https://linustechtips.com/topic/107550-lapping-and-delidding/#findComment-1437243
read.
http://forums.anandtech.com/showthread.php?t=2300800
wether its worth it is up to you, i personally wouldnt do it to a new cpu unless its out of warrenty, and id take a pic of the top first to record steppin info etc.
i still might not do it then in case i wanted to resell it a year later and replace it with a newer model or setup..
that said im a tinkerer so i might do it...
you really have to weigh it up.
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
https://linustechtips.com/topic/107550-lapping-and-delidding/#findComment-1437277
read.
This is when you DONT do it.
No warranty = no RMA.
Intel accept RMAs of delided CPUs, i dont know about AMD though.
https://linustechtips.com/topic/107550-lapping-and-delidding/#findComment-1437308
I dont RMA my own f***ups and rely on a company trying to keep people employed to fix my own mistakes.
i put a blowtorch to my graphics card...ill just RMA it, ********
https://linustechtips.com/topic/107550-lapping-and-delidding/#findComment-1437440
What are you talking about?
http://www.overclock.net/t/1313179/official-delidded-club-guide
Read the first post.
Intel need to remove the heatspreader when you send it in for RMA anyway.
https://linustechtips.com/topic/107550-lapping-and-delidding/#findComment-1437551
Why would you not use thermal paste ?
I did it with a E6700 and an E8400 and their heatsinks and saw almost 10*C difference.
I used a very thin film of TIM.  Even though they look mirror smooth there will still be microscopic flaws that the paste would need to fill.
Nothing to see here - move along.
https://linustechtips.com/topic/107550-lapping-and-delidding/#findComment-1455998
becasue it will just wring together and stay on of its flat enough, we have some grade 0 paraelles at my work which are 12"X1"X2" and one can hold the other one off the table if you wring them properly.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/107550-lapping-and-delidding/#findComment-1456522
If you are confident that your cpu's were flat to such tolerances then i'm happy for you.
https://linustechtips.com/topic/107550-lapping-and-delidding/#findComment-1456553
