I am building my first gaming PC and am wondering if I picked parts that pair well together. I am just getting into PC so any advice would be greatly appreciated!
CPU: Intel Core i9-9900k turbo unlocked https://www.amazon.com/Intel-i9-9900K-Desktop-Processor-Unlocked/dp/B005404P9I
GPU: EVGA GeForce RTX 2080 XC ULTRA Gaming https://www.amazon.com/EVGA-GeForce-GAMING-Graphics-08G-P4-2182-KR/dp/B07GHVK4KN?th=1
Motherboard: ASUS ROG Maximus XI Hero (WiFi) Z390 https://www.amazon.com/ROG-Maximus-Hero-Wi-Fi-Motherboard/dp/B07HCXT591
RAM: (2) Corsair Vengeance LPX 16 GB (2x8) DDR4 DRAM 3600MHz C16 https://www.amazon.com/Corsair-VENGEANCE-PC4-24000-Desktop-Memory/dp/B07FBVYFKH?th=1
SSD: Samsung 970 EVO Plus Series - 1TB PCle NVMe - M.2 Internal SSD https://www.amazon.com/Samsung-970-EVO-Plus-MZ-V7S500B/dp/B07MFZY2F2?th=1
HDD: Seagate Barracuda 4TB Internal Hard Drive https://www.amazon.com/Seagate-BarraCuda-Internal-Drive-3-5-Inch/dp/B07D9C7SQH?th=1
Power Supply: Seasonic FOCUS Plus 750w Gold https://www.amazon.com/Seasonic-SSR-750FX-Modular-Warranty-Compact/dp/B073GWKDVM
CPU Fan: Noctua NH-U12A https://www.amazon.com/Noctua-NH-U12A-Premium-High-Performance-NF-A12x25/dp/B07PG8F8DF
Monitor: CUK Bionic 27” QHD 1440p 1ms 144Hz with Freesync https://www.amazon.com/B27QGM-Esports-FreeSync-Adjustable-2560x1440/dp/B07HY8XGRB?th=1
Case: NZXT H700 - ATX Mid-Tower PC Gaming Case https://www.amazon.com/NZXT-H500-Computer-CA-H500B-BL-Black/dp/B07C3SKSFK?th=1
Concerns:
I think my monitor may not be high enough quality
Amazon description says my graphics card supports DDR6 RAM but I watched a YouTube video where a guy used the same graphics card and used DDR4
Not sure if my GPU is strong enough to keep up with the CPU
https://linustechtips.com/topic/1075470-building-first-gaming-pc/
Um ive got a quite a few issues with the build.
But regardless of those. Wait untill the 7th and get a zen 2 CPU instead.
Get a EX920 drive instead akd constallation ES 3tb drive instead.
Get a TXM 650 watt PSU instead of the focus gold as the entire focus line from Seasonic has issues
That reffers to the memmory the GPU is using, not the memmory the CPU is using.
Also its GDDR6, not ddr6. And GDDR6 comes one the card soldered on.
Edit: what is your budget?
What amazon says is what type of memory the GPU got. Currently the best u can get is ddr6, while the most "new" gpus use ddr5. The guy on youtube meant the typ of ram the pc/mobo got. The gpu got their own memory on them, while on laptops the intergrated gpu uses the mobo ram cuz they dont got their own ram.
Concerns:
Can you please put it in PC part picker?
I lurk
HP Spectre x360 13t late 2019
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Razer Blackwidow Lite
Steelseries Rival 3
Thanks for the input and my budget is around $2500 - $3000
Wait for Zen 2. Which drops ok the 7th. Grab the 12 core and a good board.
In other words, come back on the 8th and ask for a build with a budget. And since its your first build. 2000-2500 is way more than enough.
You are building a gaming platform, so you should focus more on the GPU, monitor, and RAM, but with that money, you can basically buy whatever you need, and by "whatever you need" I don't mean the newest stuff out there...
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
23 hours ago, Sfbay300 said:
Mainly yes, but also for homework and YouTube
Here is a 9900K spec with a 2080 ti and a nice 1440p monitor. I would hold fire though until Ryzen 3xxx comes out as you will have more choice then. The 8700K or 9700K are both good enough though if just gaming.
PCPartPicker Part List
CPU: Intel - Core i9-9900K 3.6 GHz 8-Core Processor  ($474.99 @ Walmart)
CPU Cooler: be quiet! - Dark Rock Pro 4 50.5 CFM CPU Cooler  ($88.09 @ Amazon)
Motherboard: Gigabyte - Z390 AORUS PRO WIFI ATX LGA1151 Motherboard  ($183.98 @ Newegg Business)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($69.89 @ OutletPC)
Storage: Crucial - MX500 1 TB 2.5" Solid State Drive  ($107.99 @ Adorama)
Storage: Toshiba - X300 4 TB 3.5" 7200RPM Internal Hard Drive  ($104.89 @ OutletPC)
Video Card: Gigabyte - GeForce RTX 2080 Ti 11 GB GAMING OC Video Card  ($1199.99 @ Amazon)
Case: Fractal Design - Meshify C ATX Mid Tower Case  ($94.99 @ Walmart)
Power Supply: Corsair - RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Newegg Business)
Monitor: Gigabyte - AORUS AD27QD-SA 27.0" 2560x1440 144 Hz Monitor  ($599.99 @ Newegg)
Total: $3034.79
Generated by PCPartPicker 2019-06-24 15:10 EDT-0400
CPU Cooler: Noctua - NH-U12A 60.09 CFM CPU Cooler  ($99.90 @ Amazon)
Motherboard: Asus - ROG MAXIMUS XI HERO (WI-FI) ATX LGA1151 Motherboard  ($282.89 @ OutletPC)
Memory: Corsair - Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 Memory  ($94.99 @ Corsair)
Storage: Crucial - P1 1 TB M.2-2280 Solid State Drive  ($99.89 @ OutletPC)
Storage: Seagate - BarraCuda 4 TB 3.5" 5400RPM Internal Hard Drive  ($98.30 @ OutletPC)
Video Card: Gigabyte - GeForce RTX 2080 Ti 11 GB AORUS Video Card  ($1179.99 @ Newegg)
Case: NZXT - H700i ATX Mid Tower Case  ($179.99 @ NZXT)
Power Supply: Corsair - RMx (2018) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($129.99 @ Newegg)
Total: $2640.93
Generated by PCPartPicker 2019-06-25 03:46 EDT-0400
Total: $2640.93
I like this one! ✌️?
