Hello all,
i will try to be very short in my description of what happened and what is my problem.
1. my power supply broke.
2. i got mad and build a new PC.(16gb RAM ,2060, i8700, 512 SSD + just for fun the old SSD256(from the broke pc.
3. i wanted to repair the broken pc for my wife so she can watch a movie, facebook, play light games.
4. i bought a SH supply, the seller showed me that it works by measure it with a device.
5. i install it, put the SSD back but it started but no monitor signal only once keyboard light flash.
6. i cleaned the RAM, same symptom.
7.reset the bios , same.
8. did i not connect something ?
i need some help,guys.
i attachced some photos . i will give you my skype id if this will help us communicate better. alyy.cj
Thank you you wonderful people.
https://linustechtips.com/topic/1075333-pc-start-problem/
Sometimes when your PSU breaks it can damage many components such as resisters and motherboards and onboard chips.
If you can, test the components one by one using known good ones.
Also welcome to the forum :D
Please mark as helpful and informative so my profile looks better.
quote or reply to me if you want me to reply to you.
Thanks
https://linustechtips.com/topic/1075333-pc-start-problem/#findComment-12666168
