29 minutes ago, schuumi said:
Im instiling a new motherboard, but when i tur on the PC IT just turns off again and of i start IT ut without the cpu cabel conected to the motherboard it starts up, what dos that mean do i have a to smal powersuply?
What power supply do you have? You didn't give us enough information as well. What are your specs?
I lurk
HP Spectre x360 13t late 2019
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Razer Blackwidow Lite
Steelseries Rival 3
https://linustechtips.com/topic/1075146-help/#findComment-12664625
I have a 750w powersupply and the motherboard is a msi mpg z390. IT literly what i said i conect all the cables and the PC just turns on for 1 sec and then turns off. And my Graphics card is a evga geforce gtx 1080 ti sc2 so du enyone have anny ifra why my PC wont start up?
https://linustechtips.com/topic/1075146-help/#findComment-12664634
The memory sticks maybe?
Desktop benching:
https://linustechtips.com/topic/1075146-help/#findComment-12664647
2 hours ago, jstudrawa said:
-snip-
I have a 750 watt PSU. My motherboard is an MSI MPG Z390. My GPU is an EVGA GTX 1080ti SC2. When I connect all the cables, the PC turns on for a second, then turns off again. Anyone have an idea why my PC doesn't boot?
I lurk
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Steelseries Rival 3
https://linustechtips.com/topic/1075146-help/#findComment-12664658
Ok, so first, please read this link here on the rules/suggestions before posting.
Now with that out of the way:
  • Which MSI MPG Z390 do you have? (Gaming Pro Carbon, Gaming Pro Carbon AC, Gaming Plus, etc)
  • Are there any postcodes (if available on a display on the board) or LEDs for errors lit up?
  • What cable are you plugging into where specifically on the board? (To ensure you aren't somehow plugging in something where it shouldn't be)
  • Has any of this hardware worked before, or was it tested outside of the case prior to putting it in your case?
  • What CPU is in the system?
  • What other troubleshooting steps have you tried?
As a general reminder, please try to post all specs and what you've tried in the original help request post, please. It helps expedite the process and ensures we're asking the correct questions/
"Any sufficiently advanced technology is indistinguishable from magic" - Arthur C. Clarke
Just because it may seem like magic, I'm not a wizard, just a nerd. I am fallible.
Use the quote button or @<username> to reply to people | Mark solved troubleshooting topics as such, selecting the correct answer, and follow them to get replies!
Community Standards | Guides & Tutorials Troubleshooting Section
https://linustechtips.com/topic/1075146-help/#findComment-12665839
