So I had a thread about another problem, and then I managed to fix that, but now I'm trying to overclock my RAM and it's not going the greatest, and it's apparently not that stable either? I had it set to 2800, it worked for a bit, restarted to take some screenshots of my bios settings. reset, and it took several reboots ( err, what I mean here is the PC turned on and off during the process of restarting ) so far it's only done this when the OC didn't take, and my RAM went back to 2133. I've been trying to get it to 3200 ( the rated speed for the RAM ) Link here; https://www.amazon.com/gp/product/B07BH1CQVQ/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 Now the problem arises I have screenshots of 2800 MHz, 1.28V if memory serves. Then rebooted, and bada bing bada boom, it's down to 2133 MHz, same 1.28V. Now I've rebooted again, and now it's back to 2800, I'm so lost and some guidance would be appreciated. I've never OC'd RAM before, and it's annoying. Lol
https://linustechtips.com/topic/1074998-memory-overclocking-problems/
Are you using the XMP or DOHCP profile of your mobo (and does your mobo support that speed of ram - doesn't have to but that helps) for that RAM?
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
I'd say 1.5V memory voltage max. Not because you might break the stick, but the IMC
Desktop benching:
@Jurrunio@Tristerin@Firewrath9 Well that's the funny part. I've had it up to 1.36Volts and even then it sometimes wouldn't even take to 2400, and i've never gotten it to 2800 while at anything above 1.28 I've tried XMP before, but I never really got it to go over 2400. I just don't know what kind of tolerance these sticks have. And I don't wanna brick them.
Just now, ForeverZero said:
@Jurrunio@Tristerin@Firewrath9 Update: So I upped voltage to 1.45V, and I couldn't even get to 2933. I tried XMP, as well as the memory try it, and just a normal manual OC. nothings working. Any advice?
What motherboard?  My B450 supports 2933, Ryzen 7 1700 supports 2667mhz, but I am able to achieve 3600mhz on that board
My B350 board supports 2667mhz and the R7 1700 in it supports 2667mhz, but I am able to achieve 3200mhz on that board
What about the memory timings? Make the primary timings as high as possible first.
Desktop benching:
Update the bios? Or else it's just terribly picky memory controller in the CPU and you cant do much.
Desktop benching:
Well if simply using the XMP profile fails then I would be suspicious of which RAM slots you've installed in.  Did you use the slots the manual instructed?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
19 minutes ago, ForeverZero said:
@nick name I've swapped the ram around a few times already. I couldn't OC them at all the other way. in A2 and B2 ( currently in A1/B1
What does the manual say to use?
I just checked and the manual says to use A2 and B2.  So the red slots.
1 minute ago, ForeverZero said:
@nick nameOh! I remember why I swapped my RAM around, I was having problems with my memory being weird I have another thread about it, I had half my RAM in reserve?
Oof.  Is the board new?
