So I bought some used parts to build a budget computer and plan to upgrade in the future...however I have an i53570k that is overclockable with my asrock z77 extreme4 and my cpu ghz does not go over 1.6 ghz even under stress testing or playing video games. I have turned my windows on performance mode and even gone into the bios to change some setting but nothing fixes the problem. I’ve also checked the voltage and it stays in .98 volts...my psu shouldn’t be a problem since it’s 850 w bronze... I know it’s old hardware but I don’t have the money to buy a new one yet and wanted to fix this problem.  Any help would be appreciated.
https://linustechtips.com/topic/1074936-cpu-is-stuck-at-minimum-power/
Have you checked the temps? The cpu will bottleneck itself if its overheating, this includes lowering its voltage
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
Download ThrottleStop from TechPowerUp, open up the Limit Reasons window and see if anything is showing red.  If BD PROCHOT is red, try disabling that on the main screen of ThrottleStop.  This is a common reason for a CPU to get stuck at a low frequency.  Also make sure SpeedStep and Turbo Boost are enabled in the bios.  Post some ThrottleStop pics if you need help.
Limit reasons was grayed out but I disabled bd prochot and it fix the ghz problem...my pc is running a lot better now but now it’s susceptible to over heating?  (I have a 212 evo cooler)
What is your definition of over heating?  Intel says that the Core i5-3570K can run reliably up to a peak core temperature of 105°C.  That is when thermal throttling will start to prevent the CPU from being damaged.
What temperatures are you hitting?  I used to run my 3570K at over 90°C while stress testing without any problems.
Above is hot and the next picture is really hot!  The 3570K will continue to run at full speed until it reaches its 105°C thermal throttling temperature.  The second picture includes the built in Intel GPU for a little extra heat.
oh wow i should be fine i guess because im getting temps around 80C under a load. well i really appreciate all the help you've been!
